the delta force
Interior light fault
Hello,
The interior light does not come on when one or both doors are opened on my girlfriends VR. It will work when manually switched on, but when set to come on when the doors are opened it will not illuminate.
Any help appreciated...
Stefan
I had this with the passenger door, I think that the little switches at the bottom of the door are 'Earth Switches' and over time they corrode and get a bad contact. I took the switch out (1 Screw i think) cleaned all the contact areas up and it has been fine ever since. Hope this helps, if not then i've only wasted about 20 mins of your time if you clean the switches. :roll:
Thanks renson, I'm sure I can manage 20mins. I'll let you know if it takes any longer :grin:
Stefan, when you do this if you have the drivers side out can you please note which wire's connected where? I have 2 dangling in mine and neither seem to work!
Cheers!
Oh and PS if you're at the Missus' this Sunday pop both cars over to the Swan, Pimlico for lunch? About 1pm will do it! ;)
I'm going to have a look tomorrow when I get up...
Thanks for the invite but I'm on nights until Monday and only get up about 1pm :sleeping: . I'll make it one day....
Cheers!
