David Winter 0 Posted February 28, 2009 I have a problem with main beam on the left side. I noticed the blue light on my dah was not coming on. When main beam is engaged it works on the right side but the left headlight goes off to just leave the side light. Eveything is fine on dipped beam and side light settings. Ive tried replacing the main beam bulb with the wire attached and also the the headlight bulb wich i thought would solve it. Any ideas as I need to sort this for monday. Cheers Quote Share this post Link to post Share on other sites
Supercharged 2 Posted February 28, 2009 Have you got an uprated loom fitted David? If so it maybe a relay issue... Quote Share this post Link to post Share on other sites
David Winter 0 Posted February 28, 2009 Sorry guys. Sometimes you forget to check the obvious. :cuckoo: After refering to the Corrado instructions manual I noticed that there is a 10amp fuse for each mainbeam and one of these had gone so all is now well. :D Quote Share this post Link to post Share on other sites
