BeavisJem
Boost Leak
Do you know how to test your boost levels?
1. Start Motor
2. Move the MFA selector to "2"
3. Press and hold the MFA end button (keep holding)
4. Stop motor
5. Start Motor
6. Release the MFA end button.
7. Press the MFA End button one time.
etc etc
Anyways mine were about 550 - 590 idle
1640 just before redline in 3rd
Couldn't rediline in 4th, no private road :roll:
1000 0 (Atmosphere- ala no boost, charger is bypassed)
1200 2.9 psi (Your charger is dead or big boost leak)
1400 5.8 psi (Your charger is about dead or big boost leak)
1600 8.7 psi (Your charger needs new apex strips or big boost leak)
1800 11.6 psi (Great for stock pulley, Probably needs new apex strips if 68mm pulley)
2000 14.5 psi (Great for 68mm pulley on stock charger)
2200 17.4 psi (Great for 68mm pulley on heavily ported charger, hold on to your ass fast!!)
Just wondering if this is a boost leak, i ahve a stage 4 charger and standard pulley. Personally i feel the car is a bit slugghish compared to when i got it, might just be placebo.
Any help would be great cheers
BeavisJem
you cant always trust the mfa..does sond a little low,you could try removing and inspecting all the boost hoses..and spray soapy water on the joins while its running and watch for bubbles..also inspect the intercooler for stone damage
how many miles are on the charger? and how much before the redline is your reading..mine goes up quite alot over the last few revs
