12 DEG BEN
Help Identifying the part
I have picked up a brand new fan control unit thing and need to fine out what it belongs on as it doesnt fit the Vr6. The part number is 3A0919506B. A bit miffed that it was incorrect. You can only see 919 506 in situ in the car. The first three digits would be the important ones.
It's the right number I think, but you have the "B" revision.
Actually, it's off a 9A or 2E engined car. So 2l 16v or 8v
See I figured seeing most the correct numbers and a B I thought it would be a VW revision. Sure someone on here would like a sparkly new unit. The one in my cars manky and I was replacing stuff before it gave up on me.
There's 2 different units for the VR, one with one 50A fuse, and one with a 5A, a 10A and a 50A fuse, and then theres the 4 cylinder version.
Good plan. I've already repaired my controller as a diode had melted off of the PCB when I bought the car. I'm going to swap it out completely hopefully with a nice shiny new controller from Dave for the Spal fans I'm going to fit.
