awigman
Early heater controls - broken cog
I have had issues with my early heater controls in my C. The temp control works fine but the direction of air slider is stuck on the direction of my feet. Iv got my interior out at the mo so i could have a good look behind the dash. I can see a plastic cog that is broken which is prob the reason its not working.
Does anybody know what i mean? If so is it possible to replace the cog?
Thanks
That cog pops out, just ease it out and source a replacement. I broke mine when I replaced my heater matrix :?
Matrix 006.JPG[/attachment:wfx2jmlv]Plastic cogs can be strengthened/modified by drilling out the centre and inserting small nut /bolt /washers. Think you will find perished foam on the direction flaps could be causing the problem by straining the mechanism :shrug:
