simon_miles
Oil
Hi
I'm looking to buy a VR6 I've looked at two and they both had a fair amount of oil around the bottom fount section of the engine is this normal?
not normal but not necessarily an issue either, the oil cooler is at the bottom front of the engine and if the seals are knackered then it will weep around there - easy to fix :)
