yeti 0 Posted April 12, 2009 i have fitted my old speaker set up out of the corrado into the passat and was wondering what the 3rd small wire without a connector on it is on the lead which transmits the sound from the headunit to the amp. Do i need to connect this as i havent powered up the amp yet as i've lost my amp -> sub wires and need to go the shop to get some new ones monday/tuesday Quote Share this post Link to post Share on other sites
Jim 1 Posted April 12, 2009 Is it blue? Sounds like the remote cable... Quote Share this post Link to post Share on other sites
yeti 0 Posted April 12, 2009 Is it blue? Sounds like the remote cable... thanks jim, yeah is is a blue wire, i noticed theres also a remote terminal on the amp. What does the remote do then - sorry i am a complete ice newb as i only changed speakers and headunits before and got the people who installed my alarm into the C when i got it to put the sub in Do i need to fit to somewhere on the back of the headunit and plug it into the amp, will this control it being on all the time? Quote Share this post Link to post Share on other sites
Jim 1 Posted April 12, 2009 The remote sends a signal to the remote device to switch on (and switch off again) when you turn the headunit on or off - there should be a remote wire cable you can tap into on the headunit wiring loom. And don't worry - I'm an ICE newb as well.. gave Tempest a hand a few weeks back installing a sub into my car so learned about the remote cable then :) Quote Share this post Link to post Share on other sites
Supercharged 2 Posted April 12, 2009 It's basically the switch, turn stereo on and it sends a voltage down that wire, when that voltage exists the amp is on (fairly sure it's constant and not just a pulse but hopefully someone will correct me if wrong) Quote Share this post Link to post Share on other sites
colinstubbs 0 Posted April 12, 2009 It's constant. Quote Share this post Link to post Share on other sites
