chris CORRADO 0 Posted December 27, 2003 hi i want to remove the CAT on my cat when the powerflow exhaust system is fitted.... BUT. i wanna know what is the CUT OFF date to have a CAT my car is a VW CORRADO *duhh* 2.0L 16v and it was made *** 06 / 01 / 1993*** is there like a month which is the cut off or is it just 1993 i hope it is not??? if i'm stuck with the CAT is there anyway i could have like a quick release CAT.... (maybe) or if i remove the CAT and i'm not ment to can any one sugest any dodgy MOT places who will MOT with out a CAT LOL i'm in surrey BTW.... any help would help.. ------------- chris Quote Share this post Link to post Share on other sites
h100vw 0 Posted December 27, 2003 Chris anything K reg onwards should be catted up. They are not that time consuming to swap if you have the facilities. I'd say about 30mins would do it. You must have the lambda probe fitted into the by pass pipe or suffer the consumption!!!!! Honestly, it is not worth the bother, unless your cat is knacked. Sometimes they break up and block the silencers in the rest of the system. If that happens I'd just knock whats left out of the cat and put it back on. I have to get my K plate Passat tested next week. If they don't say anything I'll let you know. Gavin Quote Share this post Link to post Share on other sites
