guy7809
problem starting my corrado
Hi all
In need of some help as my vr6 corrado will not start.
I was told by AAGUY!!!!!!!!!!!! i will need to take it to VW who will change ignition switch and new keys
The car turnes over but cuts straight out.
i have changed all plugs/plug leads/even the coil pack (cost a fortune) but no luck
Any takers please
It's the factory immobiliser. You've either got a defective key, transponder reader ring on your ignition barrel or fuse 15 is blown.
how do i go about sorting these possible problems out mate and do you know if i have to pay a fortune to get it done or could i do it myself
You need to get someone to check it on Vag Com. The sensor ring is £25ish, but the new key and reprogramming will be more. The fault code scanning will tell you which it is.
Check all your fuses first though....
Guys
Brilliant
I just took it all apart and cleaned it up and now working fine
I now need to sell GUTTED
