Toad
Fixing rust patches
Right.... I'm pretty good on mechanical work, but rubbish on cosmetic stuff. I need to fix a variety of rust patches on the VR.
Where should I start?
Most are quite small and I would like to patch the paintwork up for the time being before getting the whole car blown over at a later date....
depends where it is, I've never had much luck with 'rust killers', best bet is to ensure the metal is clean and dry (steel can absorb moisture apparently) and all the rust is removed if at all possible, gently warming the panel if it's not warm dry weather is supposed to help remove moisture from the metal, then prime with a 80/90% zinc primer. If it's on the sills or underneath the car then the overpaintable underbody sealant needs to go on top of the zinc primer before top coats.
Ive done a couple of patch repairs on my scorpio. Cleaned all the rust off, primed it, can sprayed with 3 coats and 2 coats lacquer. Looked ok for about a month and has now bubbled again :(
^ I think that's due to the metal absorbing moisture, it's a pain but you need to leave the exposed steel for quite a while with some gentle heating (direct sunshine or a lightbulb near it) before priming, particularly if a large rust patch has formed in an area that's stayed damp for a while, wheel arch, sill etc.
The other thing is fine hairline cracks forming in topcoats allowing moisture through to the primer and metal, still not sure why this happens, might be due to the thickness of coats or a poor match of primer and topcoat.
Ok. So, wire wheel, bare metal, zinc primer, skim of filler, undercoat, top coat, job done?
yeah u have to pre-heat the panel. i done the same and it bubbled. second time lucky though :dance:
