Jay2 0 Posted May 7, 2009 Used the search and now I'm more confused than ever. :scratch: Would these fit my 91 G60, its lowered about 40mm? http://www.edition38.com/forums/index.p ... try1986652 According to the search 17" need to be 205/40/17 with an ET 35 for a good fit, is this right? And are all 4x100 stud patterns the same fitting? As I've seen some for different car makes? :confused4: Thicko after some help. :cuckoo: Quote Share this post Link to post Share on other sites
BILLCOR 1 Posted May 7, 2009 They will be fine, tyres should ideally be 205/45/16 but the 195's will be ok Quote Share this post Link to post Share on other sites
carpy25 0 Posted May 7, 2009 you also need to check the center bore you need 57.1 mm or bigger a you can get rings to make the bore smaller if the bore is smaller than 57.1 you would need to get it machined larger Rob Quote Share this post Link to post Share on other sites
BILLCOR 1 Posted May 7, 2009 you also need to check the center bore you need 57.1 mm or bigger a you can get rings to make the bore smaller if the bore is smaller than 57.1 you would need to get it machined larger Rob Dont confuse him anymore :lol: they are pictured on a Mk2 Golf so should be fine :wink: Quote Share this post Link to post Share on other sites
carpy25 0 Posted May 7, 2009 pics were gone when i checked e38 post :scratch: Rob EDIT: their back now :clap: Quote Share this post Link to post Share on other sites
Jay2 0 Posted May 8, 2009 Noooooooooooooooooooooooo...........not more measurements to think about! :epicfail: Quote Share this post Link to post Share on other sites
