ashley555
Coilover fitment help
Hi guys fitted many a set without issue to mk1 and mk2s in ther past.
I bit foxed by the vr front ones though. There on the car but getting some clonking from both fronts that sounds like the springs arent mounted correctly.
The aps only came with one nut per coilover. The standard suspension has two (one on top of the spring cap and one on top of the mount).
as mine are assembled in order:
spring
spring cap
standard vw nut
bearing
rubber mount
mount top
ap nut.
The top ap nut is tight so thats not the issue. wandering if i should ditch the other nut or change the order?
thanks in advance
