TomHux 0 Posted May 9, 2009 The passenger side main beam head light dosnt work on my Vr. The drivers side is fine, and side light and main beam are fine on both sides. There is no power going to the main beam when it is switched on, so changing the bulb didnt make any difference and the fuse is ok as well. Does any one have any ideas? Quote Share this post Link to post Share on other sites
carter711 0 Posted May 9, 2009 I had trouble with my headlights a few weeks ago. the dipped beam wouldn't work on both sides. A new (secondhand) switch fixed it. HTH Quote Share this post Link to post Share on other sites
colinstubbs 0 Posted May 9, 2009 Must be a short circuit somewhere, i guess you'lll have to trace the loom back towards the switch. :( Good luck. Quote Share this post Link to post Share on other sites
C.P 0 Posted May 9, 2009 check the fuses first. iirc each side has a separate fuse. Quote Share this post Link to post Share on other sites
M15 VW 0 Posted June 9, 2009 It was working fine up until one day it just wasnt. Originally thought the bulb had just gone. Not sure if that helps you or not. Quote Share this post Link to post Share on other sites
