simon_miles 0 Posted May 11, 2009 Hi Chaps I've just brought a VR6 and am trying to get to grips with the MFA (as the car did not come with a manual) :( Can anyone tell me what all the settings are? (I know some are obvious) also when do they reset? :scratch: A mate of mines seams to think that there are secret settings is this true, if hows is it done and what are they? :shrug: Hope you guys can help loving the car I now know what all the fuss was about! :clap: Quote Share this post Link to post Share on other sites
Jim 2 Posted May 11, 2009 Switch position 1 on the stork shows you details for your current journey. It will reset if the car has not been running for 2 hours. It will show you: * Journey time * Average MPG * Miles Driven * External air temp * Time * Oil Temp MFA2 will show you oil temp / time / external air temp but show you overall averages for MPG, journey time and miles driven accumulated since the last time the battery was disconnected. Slide it inwards to 0 during a journey to reset MFA1. Quote Share this post Link to post Share on other sites
davidwort 0 Posted May 11, 2009 some if not all of the models will also display other values the ECU and clocks recieve, for instance on a 16v by holding the MFA switch across when you turn on the ignition you can see RPM, instantaneous MPG and a few other values, I think the G60 shows boost too? Can't remember the exact sequence of holding down the MFA switch and releasing, will be somewhere on the site if you search...probably. Quote Share this post Link to post Share on other sites
