bulldog12
corrado???????
can someone help me i first brought a corrado 16v cos i just loved the look of them but owning the car for more than a year and having no real probs with car untill the missus used it for school runs (wich killed it) i new my next car had to be a corrado g60 ?vr6 i endid up getting a g60 but having no real clue about these engines and seeing all these threads about this pulley and stage 4 charger etc. can any help me as a newbee on what to check first engine wise b4 i start spending money on serious mods :wave:
Have a look at the buyers guide for you PSI checks on your charger.
http://wiki.the-corrado.net/the_corrado ... klist.html
If all is good then do a compression test. If that's all good
Stick a oil cooler on it. (Unless it already has one)
Drive it like you stole it and save some £££ till the charger needs rebuilding.
(Keep checking the PSI, She'll let you know when she's tired)
Then spend some £ making it fast!
G-Werks
http://www.g-werks.com/Site/Default.asp ... ces_glader
Jabba
http://www.jabbasport.com/superchargers.php
That explains the stages a little better.
Welcome to G60 ownership! You're gonna LOVE IT!
cheers. these engines aint like a mrk 4 escorts. gonner get the charger sent off first just to be safe new cam belt there is so many things i whant doing but getting laid off last week dont help just glad i got the car any ideas on things i can do myself
a bit off both really. im having no probs at all engine wise just the only service history i have is came belt change 20 000 miles ago and little bits hear and there.just whant a bit of advice from someone with a bit of savy as to what they would do first :shrug:
Plugs, leads, oil, all belts and tensioners and a Oil Cooler (all for peace of mind)
Chip and pulley (smaller pulley means you'll need a new belt anyway to eradicate the worlds most annoying squeak, Trust me I have said squeak)
With these few little things you'll have a nicely serviced engine and peace of mind and a charger that spools up a bit faster to get things moving a bit quicker!
