Rob_G60
wheels help
Im about to order some New Schmidt TH Modern 1pc for my g60
the car has had a vr6 hub conversion and had brembo brakes fitted on the front, which are of a ibiza cupra R im sure the size is 305,
am i right in ordering 16inch 5x100 et25 they are 9s all round, to fit over the front brakes?
cheers
Rob
The new style modernlines with the concave spokes have a lot more brake clearance than the old dished style. Bally has got his 4 x 100 et15 set to clear Porsche big reds. Might be worth dropping him a pm and do some calculations in comparison to his set up to see if the 5 x 100 et 25 set will clear. The et 25 casting is the one to go for if it clears your brakes as they sit much better in the front arches.
been told by a mate they will fit and told me to get the et25 if they dont get the 10mm spacers on
Hi guys, I'm looking at 16x7.5 5x100 ET25 Schmidt Retro-ML 1-tlg for my VR6. Do you reckon these will fit inside the arches?
Dave what size tyres are you planning to run and how low will you run the car?
205,45,16 tyres. Its lowered on Konis approx 25/30 mm
Most of all I dont want the wheels outside the arches
thanks Zak
