lockdown
What cams for a 1.8 16v?
Just thinking aloud really. Seeing as its in bits at the moment I mite aswell put some shiney bits in :D.
Are there any performance cams available for the rado 1.8? Any other shiney performance related stuff I can throw in it while its in bit?
Many thanks!
loads mate - try the search for full info, as heads up piper and kent do 16v cams but they can be really peaky, you can also modify a kr/ 9a exhaust cam as an inlet which gives better lift/ duration
Anyone have any info on having the cams re ground? Cam kits is about 400 quid! Don't know if this is a cheaper option
