jonybravo 0 Posted June 24, 2009 Hi, Looking at getting some spacers for the front wheels. I have 15mm spacers (each side) at the read. And the wheels are fine in my opinion for where they sit in the arch. For the front, should i also go for 15mm either side? Or would it be advisable to go for 10mm either side. Not sure of the ET on the rims I have, they were put on the rado before I bought it Ta Quote Share this post Link to post Share on other sites
coullstar 0 Posted June 24, 2009 Best to check what the ET is first, should be stamped on the rear of the wheels. What size & width are they? Pretty sure the rear track is narrower than the front so 10mm should be ok. Always use hubcentric ones remember. Quote Share this post Link to post Share on other sites
