DanVW 0 Posted June 30, 2009 Anyone ever switched the foglight from the r/h side to l/h side? I have to move it (or enable both sides) to passthe Dutch MOT, was wondering if it is just as simple as moving the bulb as the other side is prewired and ready to go but I suspect not :lol: Quote Share this post Link to post Share on other sites
shaung60 0 Posted June 30, 2009 It is prewired so just stick a bulb in the holder. Only problems are the hole in the light cluster will be blanked over with a thin bit of plastic and there is no silver reflector inside the light cluster. Quote Share this post Link to post Share on other sites
DanVW 0 Posted July 1, 2009 Cheers :-) So its out with the small hammer and the tin foil then :clap: Quote Share this post Link to post Share on other sites
Supercharged 2 Posted July 1, 2009 Yep - will work but ideally you want to order a light of an LHD car so you get the reflector - £22 ish from VW Quote Share this post Link to post Share on other sites
DanVW 0 Posted July 1, 2009 Nice one thanks guys :-) just dropped it off at the garage so will see what the damage is at 5:00... Quote Share this post Link to post Share on other sites
Wullie 1 Posted July 1, 2009 Just had to go and check in case my memory was playing up. The fog lights and reversing lights are both wired up and working, complete with reflectors. It's a 1990 16v and assumed all Corrados would have been the same. Quote Share this post Link to post Share on other sites
