Pat_McCrotch
Headlight Issues :(
Right, in preperation for my MOT on Wednesday I'm trying to get the near side headlight sorted which despite having a new bulb wasn't working on full beam on the near side. I therefore decided to change the loom inside the light.
However, despite being what appears to be a fairly new headlight it appears someone has beaten me to it and now after changing the loom again I now have ZERO lights on the near side and hence I'm now panicking because I'm fast running out of time :(
Does anyone have any ideas as to what it could be? :(
Could very well be the switch, If it's a late spec car they have a different switch which can be unreliable, the early ones have a Mk2 Golf switch which is very robust.
A new (secondhand - I believe VW have discontinued them) switch sorted my headlight problems on my 1995 VR.
Cant see it being the switch if the lights ARE work albeit only on one side. Is it an aftermarket loom or factory? I had this issue on my last MOT it was the relays that had water ingress. :( Replaced them and all was fine.
