dubboy
Design 90 Info Required
Looking at running a set of Design 90's on a Corrado G60.
They are 7x16 for the front & 8x16 for the rear.
What size adaptors are required 20mm or 25mm
Also what is the best tyre combo for these wheels as people seem to be running different ones.
Looking for something that will sit nice in the arches but not looking for the overstretched tyre look.
I know this has been probably covered many times, but all I can find is info people running 8x16 all round with varying tyre sizes.
You need to find out what the original offset is on them and then get adapters to make them as close to ET33 as possible.
IE if they are ET52, a 20mm adapter will bring them down to ET32.
Tyres - min size on a 7" is 195 and will look ever so slightly stretched, and then 215 on the 8" I reckon
