gar32pentre
Broken Handle! Can't get in my Corrado!!!
Hi there everybody.
I've got an N-Reg Corrado which isn't letting me in through the driver side.
The handle mechanism is broken (I've compared both sides).
Also, can I change the handle without having to change the lock, I know you guys know about these things!
Door can be opened from the inside, central locking does work it's only that the handle won't open the door.
Has anyone got a spare driver side door handle that I could buy please?
Many thanks!
Ps. If anybody knows how to identify and eradicate a severe and annoying rattle from within the dash somewhere you would be a life saver!!!
You can swap barrels between handles. New handle doesn't necessarily mean different key or re-tumbling .....
But still I'd say the repair is undoubtedly better than another crappy handle.
I'm taking on board all your advice.
At the moment having searched here and on ebay I can't find a repair kit, can anyone please help me locate the one I need?
Many thanks!!
I can recommend these totally. I bought my first set on ebay from a guy that was making them in germany, it can be quite fiddly getting the retaining pin out. When I bought the new corrado the same door went so I looked for the german guy but couldn't trace. Found the above link and bought 2 (1 for each door) fitted one to the door that was knackered and its a good fit and fix. Just PM dave16v and see if he has any, good instructions come with it and even I managed it and I am not mechminded :norty: ..................................
