Wastegate86 0 Posted August 24, 2009 had a quick search but couldnt find anything usefull all the other dials work fine but speedo has just stopped reading anything but 0mph?? big wiring problem? Quote Share this post Link to post Share on other sites
borarob 0 Posted August 24, 2009 i expect it is just the cable popped off - either engine end or behind the dash cluster...... Quote Share this post Link to post Share on other sites
Baz2004 0 Posted September 12, 2009 This could be linked to your spoiler motor, i had a similar problem a few years back when my spoiler motor jammed and blue the fuse for the speedo. Best to chck the fuse board to see if there are any out before you go into the wiring. Quote Share this post Link to post Share on other sites
Wastegate86 0 Posted September 13, 2009 spoiler works fine on the manual switch heard theres a sensor conected to the transmission which might be the cause otherwise might be getting a guy well known down by my neck of the woods to have a look at the electrics behind dash Quote Share this post Link to post Share on other sites
