Erickramirez
need to remove front seats tonight, but how?!?!
i need to get my interior removed by tonight so i can sell it but im stuck, im not sure how to remove the front seats and as for the rear door panels i got them disconnected but theseat belt is in the way of letting me remove it, i tried search but couldnt really find anything if someone could please give me a link to a DIY or something or if you want to give me quick directions as to where the bolts are etc. to remove the seats i would greatly appreciate it, thanks!
if you look at the front of the seat theres a small bolt that stops the seat going too far back,remove that and the seat just slides backwards off the runners (need to unclip some plastic trim on the runners first)
There's a screw hidden in front of the rear ash tray. But I think you mean the actual cover on the lever?
You need to pull a little nubbin downward on the bottom of the hand grip which allows the hand grip to be pulled off of the lever, then the trim can be pulled off too.
Does that help?
