lockdown
Cam followers
Hello everyone. Quick question. I think they are called cam followers. I've had them out of the head for a while and all the oil has drained out of them. Can they be put back in like normal and they will work fine or if there a way of refilling them before I put them back in? Or is it just a case if having to buy a new set?
Thanks guys
Any ideas?
the bentley bible lists the following
for the engine code PG
cam follower
lubricate contact surface
do not interchange
check camshaft axial play before installing
install with contact surface down
hope that helps :)
Immerse them overnight in fresh oil, the same way they sit in the engine as this allows them to draw oil in. I actually left my new ones for a few days and I got next to no tapping when it was fired up.
