lockdown
Head gasket kit
Just got a head gasket kit. Seams to be more than I need. Do you normally fit everything you get in the kit of just what you need to?
Many thanks
If you have it all, you might just aswell replace it while you have it in bits. There is nothing worse than doing a part job and then a few months later having to go back and sort it again.
Yer im replacing all the gaskets i've taking off, but some of the stuff in the kit i don't remember taking off?! Confused a bit here haha
Yes, it probably has. I imagine it's got the coolant flange o-ring, downpipe gasket and valve stem seals in it (maybe even more) .. all things that you might as well replace while you've got access to them.
