B41LEY
Few problems turned into complete engine rebuild
1992 VR6, 109k.
Known problems when i took it to the garage:-
Blown head gasket
Original timing chains, pulleys, tensioners etc
Noisey tappetty engine
Leaky radiator
No receipt for it ever having a clutch
Using oil
Few pics of work in progressCorrado conversion V2 (3).pdfSDC10542.JPG[/attachment:2owllbpp]Book1.pdfSDC10543.JPG[/attachment:2owllbpp]stromlaufplan_gamma4.pdfSDC10545.JPG[/attachment:2owllbpp]ETKA Corrado.pdfSDC10546.JPG[/attachment:2owllbpp]stromlaufplan_gamma4.pdfSDC10547.JPG[/attachment:2owllbpp]Corrado92.pdfSDC10548.JPG[/attachment:2owllbpp]passat climatronic wiring diags.pdfSDC10550.JPG[/attachment:2owllbpp]climatronic wiring-Golf from May 01.pdfSDC10551.JPG[/attachment:2owllbpp]2.8l 24v Climatronic system.pdfSDC10552.JPG[/attachment:2owllbpp]SDC10553.JPG[/attachment:2owllbpp]
New parts fitted and work done:-
Head gasket set, set of head bolts, radiator, skim cylinder head, hydraulic lifters, chains and tensioners, set big end shells, set rings, water pump, clutch, distributor cap, fan belt tensioner, fan belt, coolant reservoir, plugs, several hoses seals lots of bolts etc etc and some other bits that have been forgotten.
In all, the garage had it a week. Huge bill that just kept getting bigger! Should be good for another 100k now! Ian
Good to see you are taking proper care of your engine! How much will it cost do you rekon? I know that there's a company that fits a reconditioned VR^engine for £2000 exchange.
