half-9 0 Posted January 15, 2004 Hi, The water temp warning light is flashing, but the water temp guage seems to be working fine, the oil temp is also within the normal range. The fan is also swithching on & off as per normal. Does the light flash if the coolant level is low or if there is a leak or something?? Cheers - its a G60 Quote Share this post Link to post Share on other sites
Henny 0 Posted January 15, 2004 yup, it's also a water level warning light... Check that your coolant level is OK when the engine is cold... 8) Quote Share this post Link to post Share on other sites
