half-9
Water temp warning light flashing but water & oil temp i
Hi,
The water temp warning light is flashing, but the water temp guage seems to be working fine, the oil temp is also within the normal range. The fan is also swithching on & off as per normal.
Does the light flash if the coolant level is low or if there is a leak or something??
Cheers - its a G60
yup, it's also a water level warning light... Check that your coolant level is OK when the engine is cold... 8)
