JasonSanders
Bumper Removal Help, Urgent PLease
Assuming you have removed the chin spoiler do the followinh
first jack the car up onto stands, remove and disconnect fog and indicators plus air temp sensor on the inside of the chin spoiler on the right hand side of the car.
now crawl under the car and look up at the main cross member under the engine. on each side you will see three bolts. the two outer ones hold the bumper in (NEVER UNDO THE MIDDLE ONES) otherwise the engine will fall on you. DO NOT MOVE THE CAR WITH THE BUMPER OFF.
the rear bumper is held in with the same size bolts all be it at the rear, the bolts are hiden in the chassie and you need to look striaght up at them to see them.
Remember to reconnect all the lights after and the air temp sensor.
more info here http://the-corrado.net/.archive/forum/viewtopic.php?p=&t=273
