John-M 0 Posted November 24, 2009 I need to replace the (drivers side) headlight level adjuster. I have a new one, but can't seem to remove the old, broken, one. Do you have to remove the headlight, take off the glass lens, and remove anything from inside ? Or is it that I'm not applying sufficient brute force when trying to remove it from the back of the whole headlight housing ? Any hints would be gratefully recieved :) Quote Share this post Link to post Share on other sites
Bruno 4 Posted November 24, 2009 I need to replace the (drivers side) headlight level adjuster. I have a new one, but can't seem to remove the old, broken, one. Do you have to remove the headlight, take off the glass lens, and remove anything from inside ? Or is it that I'm not applying sufficient brute force when trying to remove it from the back of the whole headlight housing ? Any hints would be gratefully recieved :) You do have to remove it. It isnt a big deal to do that. It is possible to remove it without removing the lens, but there is a serious danger that if you pull it wrongly, you damage the seat which the new one pushes into. Best to remove the lens. - Use surgical gloves - the vacuum coating on the reflector degrades rapidly after it the natural oil on your skin comes into contact with it. - Then stare at the new adjuster, you will see how it is meant to lock into place. - Then peer through the back of the reflector as you jiggle the old one out. - Refit, and at night adjust it to match the position of the other lamp (hoping that that one isnt out). If this is the first time you've taken apart the headlamp, give yourself 1-2 hours to remove, do the change and refit. Quote Share this post Link to post Share on other sites
John-M 0 Posted November 25, 2009 OK, thanks for that. Job for tomorrow morning. ll post progress :) or lack of :( Quote Share this post Link to post Share on other sites
John-M 0 Posted November 26, 2009 All done, nowhere near as difficult as I'd thought it would be. Thanks for the guidance. Quote Share this post Link to post Share on other sites
