stingman123 0 Posted November 27, 2009 Hi All, hoe you can all hel with a quick query, i've got no lights coming up on the center console (heater lights etc) I actually snowing outside so..... what do you all think,blown fuse? or circuit board? would any of you all know which fuse no I'd need to check? TIA Quote Share this post Link to post Share on other sites
warren 0 Posted November 27, 2009 i would probably check the bulb first?! make sure its not blown? i actually only done mine this morning because mine had blown :? Quote Share this post Link to post Share on other sites
stingman123 0 Posted November 28, 2009 checked the buld, all ok fuse seems ok as well? Quote Share this post Link to post Share on other sites
volksworld13 0 Posted November 28, 2009 hi if the bulb isnt blown, check you have voltage at the terminal, multimeter black on earth red on pin, i think its a 12v feed, but as it is a small bulb it maybe less? if there is no voltage , ideally a wiring diagram would, inspect the loom going inbehind the dash for damage to the wires or similarly swaped the heater controls over with a know good set, and test it! :? Quote Share this post Link to post Share on other sites
