ratacus10
need uregent help- wiring snag.
Hello there folks! I've recently treated myself and bought a corrado G60 :D However when I arrived home last night after having taken it out for a drive, I wasn't able to turn off the parking lights by centering the indicator stalk. Is this a known problem with the corrados? And how can it be fixed? Your help would be much appreciated guys and girls, my battery is draining as we speak :scratch:
I've had three 'rados and loads of Golf's before that. Not one with that problem. This isnt simple, as you need to trace why the crossover isnt resetting.
First pull out fuses 7 and 8. That will kill those sidelights.
Then try changing relay 4, ie the one with number 18 on the front. It is meant to be the main relay to handover power to the "accessories on" setting of the ignition switch.
Failing that, I would get a multimeter out and check whether your ignition switch is turning on your accessories, because if it isnt, then that would explain the lack of power to switch the quarter lights back over to your headlamp switch.
Otherwise I would get a corrado circuit diagram and start tracing whats happened.
