ja32953
any answers?
also guys,....the hose from the ecu(meter long)..how crucial is that meter,and which one of the two nipples on the back of the throttle body does it go to,..bottom or top?.....oh,....at the top of my intake my after-run fuel switch,....i dont plaug it in,..cuz if i do when i shut down the pump stays running,...doesnt seem to change the driving condition tho,.....hmmm?
It does need to be a metre long, if you were to shorten it by 5cm/2inches you would start to notice the difference.
I am pretty sure it goes on the top outlet at the TB. If I am wrong it'll drive really nasty.
Pump after run is to cool the fuel preventing vapourlock and improve hot starting. You may have wiring problem if the pump is always on.
Gavin
