Teji
Heaters
alrite people, my heaters have stopped working ????
working fine before on all speeds and everything, i bascially took my headunit out this morning and now i got nothing ???
checkd the fuse, it was blown (the blower fuse) so replaced that and still nothing at all????
please help, its cold outside !
what year is your c , recheck the connection to the heater controls you may have disturbed this, does the fuse blow as soon as you put another in or when you turn the blowers on?
First time turning my heater on after replacing the matrix my thermal fuse went. Might be worth checking if you have checked everything else, especially considering its only £0.49 (maybe a little more if your as bad at soldering as me :))
