Oliver2
Original Headlights/Wiring
Hi my Headlights havn't had any of the wriring uprated but have just began having a problem with the Full Beam not working.
When I pull back the stalk my headlights just turn off altogether, however I have no idea where the relays for the headlights are? I read somewhere that there between the passenger side headlight and battery but I can't find anything. Any ideas anyone? Cheers Oli
You need to chase the loom from the battery to the lights - it will probably be a dead relay or bad connection.
Maplins relays seem to be the only ones that last but if the loom looks bad I would bin it from a safety point of view, you will need to plug in the dim - dip resistor too if removing an uprated loom.
