transitman 0 Posted December 26, 2009 Ok guys I have an issue with my central locking... when you go to unlock or lock the car with the key in the drivers side, the central locking does not operate the rest of the locks... I have to go to the passenger side to unlock the rest of the car and the central locking will then work, including the drivers door... So my 1st thoughts were drivers door handle defective... I changed this and it is still the same... I can use the alarm fob and it opens and locks fine... So what else can it be?? Mark Quote Share this post Link to post Share on other sites
BeavisJem 0 Posted December 26, 2009 If you push the Lock pin down on the drivers side (door closed) does it lock the whole system? If yes it might be the wiring to the handle, if not then it might be the wiring on the central locking pump in the door, The pump should trigger the system when you push the pin down. Beavisjem Quote Share this post Link to post Share on other sites
transitman 0 Posted December 27, 2009 I shall try that in a min... although I just went to lock the car and the central locking worked to lock the car... but then I tried to open again and it didnt work... a 1 off!! lol Quote Share this post Link to post Share on other sites
transitman 0 Posted December 29, 2009 Nope that doesnt work either... Quote Share this post Link to post Share on other sites
