BigTartanJudge
G60 engine sensors
Hey all, merry xmas.
I was thinking about replacing all the sensors on my G60 engine when all the other engine work will be carried out. Trouble is, I don't know how many there is and where they all are, the only ones I know of are the lamda sensor for the exhaust, (blue ?) coolant temperature sensor, and the CO pot in the boost-pipe. Could someone help me out with the names and location of any others ?
Cheers,
BigTartanJudge
They are the three key ones along with the MAP sensor (inside the ECU) and the hall sender on the dizzy.
Other stuff I would do are the throttle switches, ignition switch, FP and ECU relays, oil temp and pressure senders (as they can leak)
