culshaw
Part number help
Top picture is the resupply pipe "b 536 614 736"
Second Picture is the pressure regulator "034 133 534 F"
The part no.above is correct for the FPR on a 9A engine but that pipe is simply the feed to the clutch master... (not the one to the ABS valve block)
857 721 453
Yep, that's the number I posted - you have to cut to length so keep the old one for now...
If you're desperate any 8mm ID fuel hose will do
