crw-corrado 0 Posted January 5, 2010 what pcd and offset do i need to find these in to fit a rado? cheers for info Quote Share this post Link to post Share on other sites
dukest 0 Posted January 5, 2010 they will only be 5x130 so you need adaptors which will reduce your offset by 20-25mm. so if you start with an offset of ET50+ you'll end up with ET20something which will work Quote Share this post Link to post Share on other sites
Adski 0 Posted January 5, 2010 What widths do you have? as some here differant offsets, See my build thread as if fitted D90's to mine, Adam. Quote Share this post Link to post Share on other sites
__Andy__ 0 Posted January 5, 2010 5x130 pcd, so you'll need either 5x100- 5x130 or 4x100-5x130. 8'' d90's have an offset of 52.3 or 53.2, cant remember which exactly. Quote Share this post Link to post Share on other sites
lil b 0 Posted March 31, 2010 ive got a set of D90'S the 8" ones will 30mm adaptors be too much?? im on standard suspension at the moment bexs x Quote Share this post Link to post Share on other sites
dukest 0 Posted March 31, 2010 25s would be a bit better but if you're on standard suspension then it wont matter - they should look well placed in the arches but if you lowered the car then they would rub on the arch sooner than if you had slightly narrower adaptors. no issue for now though and 205 tyres will mean its not too bad if you do. Quote Share this post Link to post Share on other sites
lil b 0 Posted April 1, 2010 cool just ive seen some adpators on here and he is selling 30mm or 20mm and ive been told 20mm will look lost in the arch ... Quote Share this post Link to post Share on other sites
