crw-corrado
porsche d90s
they will only be 5x130 so you need adaptors which will reduce your offset by 20-25mm. so if you start with an offset of ET50+ you'll end up with ET20something which will work
What widths do you have? as some here differant offsets,
See my build thread as if fitted D90's to mine,
Adam.
5x130 pcd, so you'll need either 5x100- 5x130 or 4x100-5x130.
8'' d90's have an offset of 52.3 or 53.2, cant remember which exactly.
ive got a set of D90'S the 8" ones will 30mm adaptors be too much?? im on standard suspension at the moment
bexs x
25s would be a bit better but if you're on standard suspension then it wont matter - they should look well placed in the arches but if you lowered the car then they would rub on the arch sooner than if you had slightly narrower adaptors. no issue for now though and 205 tyres will mean its not too bad if you do.
cool just ive seen some adpators on here and he is selling 30mm or 20mm and ive been told 20mm will look lost in the arch ...
