EVANS1
heater booster vr6 corrado
Hi there,can anybody help went to go out in the corrado today,well we all know what the weathers like,needed heater fan on,nothing,nada,zilch,not even the booster,got to the switch and checked and theres power to it,checked fuses o.k,any ideas please,could it be the resistor,now half hour later with engine ticking over it seems to be overheating,fans don't come on to cool,but when i switch engine off,fans come on,any advice would be appreciated,Paul
Two problems.
First the blower. If you look carefully, theres a way of turning, and lifting the blower out of its housing. Remove it, and run a 12 volt feed direct onto it to make sure it does actually respond to power. If it doesnt, you've likely got knackered brushes. You have two options:
- if you know anything about electric motors, replace the brushes (look up 'valeo+brushes' on ebay, contact the guy, identify the bower you have); but before you install the new brushes make sure you spin the armature and use a good oiled block to smooth the armature, otherwise it will wreck the brushes in 3 months again;
- if you dont, search for a new blower motor - some are being sold on this forum.
The second problem is solved by looking at this thread.
viewtopic.php?f=1&t=68720
If you want to do it in a hurry change the following (as a probable cause):
- radiator fan switch;
- the two temp sensors at the front of the engine.
Cheers for that especially second problem,everything was going fine on corrado,till this lovely weather came along,anyway much appreciated,Paul
