ja32953 0 Posted January 22, 2004 hey guys thanks for your help,..i finally got the gauge cluster out,...seems to be ok,.nothing looks fried or cracked,..the electrical pulg has like 20 color wires,..which is ground?..also...as i mentioned before,..i have no fuel,oil,water,or speedo..but when i turn on the lights it lights up,.blinkers work as well as battery abs lights....so is this a ground problem?...when i was under dash...i also found a lil plug,.two wire..one blue one brown...cant figure out where it goes?..manual anyone Quote Share this post Link to post Share on other sites
ja32953 0 Posted January 22, 2004 hey guys, thanks for your help,..i finally got the gauge cluster out,...seems to be ok,.nothing looks fried or cracked,..the electrical pulg has like 20 color wires,..which is ground?..also...as i mentioned before,..i have no fuel,oil,water,or speedo..but when i turn on the lights it lights up,.blinkers work as well as battery abs lights....so is this a ground problem?...when i was under dash...i also found a lil plug,.two wire..one blue one brown...cant figure out where it goes?..manual anyone ..also,..is there an adjustment for the gas pedal...i seen the air-like plunger..? looked again,..there are similar two wire plugs..one going to the brake pedal the other the clutch...dont know where it goes...i thought it might have went to the cluster(thinking reason for them not working),..but not it?....i dont have a manual,..so i cant look it up,....weird that it was fine before block swap and now only tach works,....and idiot lights.and they still light up when switched on? the wing works fine,..and my dash speaker is already hooked up to its proper wire,..why would everything not work but the tach,...oh,...when i turn the key the clock is on,but when i turn it over to start it,..its gone again i know that i poated this issue already and got a few replies,.but nothing has helped yet,..its quite puzzling,...e info or manual would be great,..plz.. Quote Share this post Link to post Share on other sites
VR6 0 Posted January 22, 2004 As I said in my pm, you would have better results if you keep it all in one thread. We don't need a new thread everytime you have a new question on the same subject. Quote Share this post Link to post Share on other sites
