UKG Grant
changing CV boot
Just a quick one, going to change the CV boot this weekend, Can i do it with just taking the hub off, or does it have to come off from the gear box side?
cheers!
Grant
Yeah if it's just the outer boot you have to change you can do it by just removing the driveshaft from the hub. I'd remove the hub nut, disconnect the hub carrier etc from the suspension leg/wishbones so you can pull the driveshaft out from the hub then you can do it all in situ. It's simple enough to do, just messy!
