antinkariba 0 Posted February 3, 2010 The Corrado is going for its MOT next week. This weekend I am doing: The front brakes - discs and pads The steering rack boot What else should i think about doing/looking at? Quote Share this post Link to post Share on other sites
OllieVR6 0 Posted February 3, 2010 Check the front top mounts, there was a thread recently showing the difference between a good one and a shagged one. That's all I got warnings for this year. Quote Share this post Link to post Share on other sites
antinkariba 0 Posted February 3, 2010 Check the front top mounts, there was a thread recently showing the difference between a good one and a shagged one. That's all I got warnings for this year. Cool, they are new anyway - less than 8 months old! Quote Share this post Link to post Share on other sites
davidwort 0 Posted February 3, 2010 blimey, anything really :) a lot of the MOT is visual, check brake pipes for corrosion, steering and CV boots and ball joints and track rod ends for splits, dampers for leaks and all your lights, fogs aren't actually in the MOT AFAIK but main bean is now as well as dip, ropey dip beam patterns are a common corrado fail as the reflectors tarnish with age. screen chips? tread depth and any excessive oil/coolant leaks perished wiper blades rear wheel bearings have a small amount of play, that's OK, but not excessive Quote Share this post Link to post Share on other sites
delfinis38 1 Posted February 3, 2010 If you want a full list look in the back of any haynes manual ! Mines in for a MOT next month, wil need to sort some tyres out first though ! Quote Share this post Link to post Share on other sites
antinkariba 0 Posted February 3, 2010 blimey, anything really :) a lot of the MOT is visual, check brake pipes for corrosion, steering and CV boots and ball joints and track rod ends for splits, dampers for leaks and all your lights, fogs aren't actually in the MOT AFAIK but main bean is now as well as dip, ropey dip beam patterns are a common corrado fail as the reflectors tarnish with age. screen chips? tread depth and any excessive oil/coolant leaks perished wiper blades rear wheel bearings have a small amount of play, that's OK, but not excessive One of my front fogs doesn't work - I think its a wiring issue somewhere else, but if its not in the test then thats ok. I'll give everything a clean up and make sure there are no leaks. I do have a chip in my windscreen but its small at the moment. I need to get round to it. Quote Share this post Link to post Share on other sites
belfastfumanchu 0 Posted February 3, 2010 Check flexi hoses incase theyve become perished or buldged. Quote Share this post Link to post Share on other sites
