jonybravo
Hand Brake
You need to first remove the hand brake handle, underneath it is a little tab that you need to hold away before it will release. I found a small flat head screwdriver rammed in there helped as they can be a bit of a stubborn fatherless child to pull off.
cheers for the advice, any idea if the item (link) that I want off ebay will fit the rado? I emailed the guy and he said it was a universal fit but couldn't guarantee if it would fit a corrado :confused4:
It´s possible it will fit but i doubt it as the corrado hand brake isnt round its slim though you might be able to get a sleave for it.
I fitted the exact momo hand brake on a mates chavd up FTO and it looked pants on that so id go for a new original one if your has worn out
