jpowell79
VAGCOM fault codes
If you have a VAGCOM cable and need to check the fault codes, the VAGCOM and ODB II fault codes can be found here:
0 No issues detected
257 ABS Inlet Valve - Left Front (N101)
258 P0753 Shift Solenoid 1 - Open Circuit or Short to Ground or B+ (N88)
259 ABS Inlet Valve - Right Front (N99)
260 P0758 Shift Solenoid 2 - Open Circuit or Short to Ground or B+ (N89)
261 ABS Inlet Valve - Rear (N103)
262 P0763 Shift Solenoid 3 - Open Circuit or Short to Ground or B+ (N90)
263 Transmission 0107 - Machanic/Hydraulic Malfunction
264 P0748 Shift Solenoid 4 - Open Circuit or Short to Ground or B+ (N91)
265 ABS Outlet Valve - Left Front (N102)
266 P0773 Shift Solenoid 5 - Open Circuit or Short to Ground or B+ (N92)
267 ABS Outlet - Right Front (N100)
268 P0748 Shift Solenoid 6 - Open Circuit or Short to Ground or B+ (N93)
269 ABS Outlet Valve - Rear (N104)
270 P1778 Shift Solenoid 7 - Open Circuit or Short to Ground or B+ (N94)
271 See VW Service Manual (Repair group 1)
273 ABS Inlet Valve - Right Rear (N133)
274 ABS Outlet Valve - Left Rear (N134)
275 ABS Outlet Valve - Right Rear (N135)
276 ABS Outlet Valve - Right Rear (N136)
277 ABS Inlet or Outlet Valve - Left Front (N137)
278 ABS Main Valve (N105)
279 Differential Lock Valve 1 (N125)
280 Differential Lock Valve 2 (N126)
281 Vehicle Speed Sensor - No Signal (G68)
282 Throttle Position Actuator -V60
283 P1711 ABS Wheel Speed Signal #1 (Left Front) - Range/Performance - G47
284 ABS Inlet or Outlet Valve - Right Front - N138
285 P1716 ABS Wheel Speed Signal #2 (Right Front) - Range/Performance - G45
286 ABS Inlet or Outlet Valve - Left Front - N139
287 P1721 ABS Wheel Speed Signal #3(Right Rear) - Range/Performance (G44)
289 ABS Inlet or Outlet Valve - Right Rear (N140)
290 P1726 ABS Wheel Speed Signal #4 (Left Rear) - Range/Performance. (G46)
291 Pressure / Fluid Level Warning Switch (F116 / F117)
292 Hydraulic Energy Supply Pressure Level
293 P0705 Multi-Function Transmission Range Switch - Malfunction (PRNDL Input) (F125)
294 Transmission Pressure Switch L (F174)
295 Transmission Pressure Switch 2 (F175)
296 P1704 Kick-down Switch - Short to ground (F8)
297 P0715 Input/Turbine Speed Sensor Circuit - Malfunction
297 P0721 Vehicle Speed Sensor Circuit - Range/Performance - Signal Noisy (G38)
297 P0722 Vehicle Speed Sensor Circuit - No Signal
297 Transmission Vehicle Speed Sensor (G38)
298 Rear Differential Lock Switch -E121
299 Transmission Shift-Range Program Switch - Short Circuit -E122
300 P0712 Transmission Fluid Temperature Sensor Circuit Low Input (G93)
300 P0713 Transmission Fluid Temperature Sensor Circuit High Input (G93)
301 ABS Return-flow Pump (V39)
302 ABS Solenoid Valve Relay (J106)
303 Board Computer Function Selector Switch (E91)
305 Fuel Consumption Indicator Signal
306 Secondary Air Injection - Cylinder Bank 1
307 Secondary Air Injection - Cylinder Bank 2
309 Cleaning Solution Metering Pump (V135)
310 Catalytic Convertor Temperature Sensors (G20)
312 Catalytic Convertor Control Temperature Sensors (G132)
313 Three Way Catalytic Converter - Signal Malfunction
314 EGR Two Way Valve (N161)
447 ABS-ASR Motor - Electrical Connection 2
501 Central Flap Motor Position Sensor -G92
512 P0341 Cam Sensor - Signal Error
512 Camshaft Position Sensor - Not on Reference Mark
513 P0506 Engine Speed Sensor - G28 - Idle RPM Too Low
513 P0507 Engine Speed Sensor - G28 - Idle RPM Too High
513 Engine Speed Sensor - G28 - Signal Malfunction
514 P0336 Crankshaft Position Sensor - Erratic Signal - G4
514 Crankshaft Position Sensor - G4
515 P0340 Camshaft Position Sensor (Hall Effect Sensor) - No Signal (G40) : Check CMP, if
OK, replace distributor.
515 Camshaft Position Sensor (Hall Effect Sensor) -Short to B+ (G40) : Check CMP, if
516 Throttle Position Sensor - Closed Switch -F60
517 Throttle Position Sensor - Wide-open Switch -F81
518 P0121 Throttle Position Sensor - Signal Out of Range (G69) Also check for loose ECM
power relay.
519 P0106 MAP Sensor - Out of Range -G71
519 P0107 MAP Sensor - Voltage Low -G71
519 P0108 MAP Sensor - Voltage High -G71
520 Volume Mass Air Flow Sensor -G19ig70
521 Co Fuel Trim Potentiometer -G74
522 Engine Coolant Temperature Sensor -G62
523 P0112 IAT Sensor - Temp High - Circuit Low - G42
523 P0113 IAT Sensor - Temp Low - Circuit High - G42
524 Knock Sensor 1 -G61
525 P0131 O2 Sensor - Voltage Low -G39
526 Brake Light Switch - Incorrect signal (F)
527 Intake Air Temperature Sensor - G72
528 Barometric Pressure Sensor - F96
529 P0725 Engine Speed Input Circuit (RPM Sensor) - Malfunction. Also check for loose
ECM power relay.
529 P0727 Engine Speed Input Circuit (RPM Sensor) – No Signal
530 Throttle Position Sensor -G88
531 Mass Air Flow Sensor Reference Voltage
532 P1746 Transmission Control Module Relay - Supply Voltage (B+) Malfunction Low
Battery or Bad Ground
532 P1750 Supply Voltage (B+)
533 Idle Air Control Regulation
534 Oil Temperature Sensor -G8
535 First Knock Sensor
536 Second Knock Sensor
537 Oxygen Sensor Control
538 Reference Voltage
539 Fuel Temperature Sensor -G81
540 Knock Sensor 2 -G66
541 Slide Travel Sensor -G99
542 Needle Lift Sensor -G80
543 P0726 Engine Speed Input Circuit - RPM Upper Limit Exceeded
544 Maximum Charge Air Pressure Exceeded
545 P1780 Engine Intervention Unreadable. Also check for loose ECM power relay.
545 P1781 Engine Intervention Stuck Off. Also check for loose ECM power relay.
545 P1782 Engine Intervention Stuck On. Also check for loose ECM power relay.
546 Data Communication Line Faulty
547 ABS Pressure Control Switch -F137
548 P0560 System Voltage Malfunction
549 Fuel Consumption Signal
549 P1771 Load Signal Stuck Off (RPM Signal missing)
549 P1772 Load Signal Stuck On (RPM Signal missing)
550 Injection Start Control
551 Catalytic Convertor Excess Temperature
552 Volume Air Flow Sensor (Position Sensor) -G19
553 Mass Air Flow Sensor -G70
554 Oxygen Sensor 2 - Control
555 Heating Circuit - Oxygen Sensor 2 -G108
558 Mixture Control Adjustment Limit - Lean Position
559 Mixture Control Adjustment Limit - Rich Position
560 EGR Temperature Sensor Switch Short or Implausible Value
561 Mixture Adjustment Control
575 Manifold Absolute Pressure Sensor
577 Knock Sensor Control - Cylinder 1
578 Knock Sensor Control - Cylinder 2
579 Knock Sensor Control - Cylinder 3
580 Knock Sensor Control - Cylinder 4
581 Knock Sensor Control - Cylinder 5
582 Knock Sensor Control - Cylinder 6
583 Knock Sensor Control - Cylinder 7
584 Knock Sensor Control - Cylinder 8
585 EGR Temperature Sensor - G98
586 EGR System Control
587 Mixture Control Adjustment Limit - Bad ECU ground, Air leak, Leaking Injector.
588 Air-bag Ignition Circuit - Driver Side -N95
589 Air-bag Ignition Circuit 1 - Passenger Side -N131
590 Air-bag Ignition Circuit 1 - Passenger Side -N132
591 Seat Belt Tensioner Switch - E24
592 Seat Smelt Tensioner Switch - E25
593 Seat Detect Switch - Passenger Side -F151
594 Air-bag Ignition Circuit
595 Crash Data Already Stored
596 Injector or Trans. Solenoid Wires - Short
597 P1728 Varying ABS Wheel Speed Signals - Range/Performance
598 Hydraulic/Mechanical Malfunction
599 Possibility-pressure Brake Light Switch
600 Temperature Regulator Flap Motor Position Sensor -G92
602 Foot-wall/defroster. Flap Motor Position Sensor -G114
603 Foot-wall/defroster Flap Motor -V85
604 Back Pressure Flap Motor Position Sensor -G113
605 Fresh Air Recirculation Flap Two-way Valve -N63
606 Engine Coolant Two-way Valve -N147
607 Outside Air Temperature Display -G106
608 Load Sensor -G119
609 Ignition Output 1
610 Ignition Output 2
611 Ignition Output 3
612 Ignition Output 4
613 Ignition Output 5
614 Ignition Output 6
615 Ignition Output 7
616 Ignition Output 8
617 Air-bag Deceleration Sensor - Left -G104
618 Air-bag Deceleration Sensor - Right -G105
619 Sensor Supply Line - Left
620 Sensor Supply Line - Right
621 Pressure Reduction Valve -N155
622 Draining Water from Fuel Filter
623 ABS/Transmission Electrical Connection
624 A/C Compressor Engagement
625 Vehicle Speed Signal
626 Glow Plug Indicator Light -29
627 Water Level Sensor -G120
628 Actuating Variable Control
629 Vacuum Vent Valve - Brake -F47
630 A/C Switched on
633 Wiring to Ignition/sensor for Delay
634 Series Resistance -N159
635 Oxygen Sensor Heating Circuit - Ahead of Catalytic Convertor
636 Acceleration Sensor - Right Front - G121
637 Acceleration Sensor - Left Front - G122
638 P1766 Throttle Angle Signal - Stuck Off. Also check for loose ECM power relay.
638 P1767 Throttle Angle Signal - Stuck On. Also check for loose ECM power relay.
638 Engine/Transmission Electrical Connection 2. Also check for loose ECM power
relay.
639 Deceleration Sensor -G123
640 Oxygen Sensor Heating Relay -J278
641 ATF-Temperature too High
642 EDL Switch-over Valve - Right Front - N166
643 EDL Outlet Valve - Right Front - N167
644 EDL Switch-over Valve - Left Front -N168
645 EDL Outlet Valve - Left Front - N169
646 ABS-ASR Motor - Electrical Connection 1
648 Oxygen Sensor Heating Circuit - Behind Catalytic Convertor
649 ABS Inlet/outlet Valve - Rear -N160
650 Clutch Vacuum Vent Valve Switch -F36
651 Ignition Wiring
652 P0730 Transmission Shift-Range Controller - Incorrect Gear Ratio
652 P0731 Transmission Shift-Range Controller - Gear #1 - Incorrect Ratio
652 P0732 Transmission Shift-Range Controller - Gear #2 - Incorrect Ratio
652 P0733 Transmission Shift-Range Controller - Gear #3 - Incorrect Ratio
652 P0734 Transmission Shift-Range Controller - Gear #4 - Incorrect Ratio
653 Automatic Transmission Selector Lever
654 Seat Belt Tensioner Igniter 1 -N153
655 Seat Belt Tensioner Igniter 1 -N154
656 Air-bag Seat Detect Sensor -G128
657 Center Vent Adjusting Motor -V102
658 Operating Module
659 Self Test
660 Kick-down Switch / Throttle Position Sensor
661 Temperature Indicator
662 Tachometer -G5
663 Speedometer -G21
664 Fuel Gauge
665 Seat Belt Warning Light -K19
666 Signal
667 Ambient-temperature Signal
668 Battery Power Voltage Supply (Terminal 30)
669 Secondary Mil -K97,
670 Throttle Position Sensor -G127
671 Cruise Control Switch -E45 - Undefined Switch Position
672 ABS Hydraulic Pump with Series Resistance
673 Brake Pedal Pressed
674 Brake Released
675 IV-Left Front: OV OV-Left Front; OV - Left Front Wheel Locked
676 IV-Left Front: B+ OV-Left Front: OV - Left Front Wheel Locked
677 IV-Left Front: B+ OV-Left Front: B+ - Left Front Wheel Free
678 IV-Left Front: B+ OV-Left Front: OV - Left Front Wheel Free
679 Oxygen Sensor Heating Circuit in Front of Catalytic Convertor
680 IV-Right Front: OV OV-Right Front: OV - Right Front Wheel Locked
681 IV-Right Front: B+ OV-Right Front: OV - Right Front Wheel Locked
682 IV-Right Front: B+ OV-Right Front: B+ - Right Front Wheel Free
683 IV-Right Front: B+ OV-Right Front: OV - Right Front Wheel Free
684 Oxygen Sensor Heating Circuit. Behind Catalytic Convertor
685 IV-Left Rear: OV OV-Left Rear: OV - Left Rear Wheel Locked
686 IV-Left Rear: B+ OV-Left Rear: OV - Left Rear Wheel Locked
687 IV-Left Rear: B+ OV-Left Rear: B+ - Left Rear Wheel Free
688 IV-Left Rear: B+ OV-Left Rear: OV - Left Rear Wheel Free
689 Outside Air in Intake Air System
690 IV-Right Rear: OV OV-Right Rear: OV - Right Rear Wheel Locked
691 IV-Right Rear: B+ OV-Right Rear: OV - Right Rear Wheel Locked
692 IV-Right Rear: B+ OV-Right Rear: B+ - Right Rear Wheel Free
693 IV-Right Rear: B+ OV-Right Rear: OV - Right Rear Wheel Free
694 Switch and Instrument Lighting
695 Hydraulic Pump (B+) - Left Front/right Front Wheel Looked
696 ABS Pressure Reducing Valve. -N170
697 ABS Pressure Reducing Valve. -N171
698 Control Module Increased Current Consumption
699 Oxygen Sensor I - Behind Catalytic Convertor -G130
700 Oxygen Sensor 2 - Behind Catalytic Convertor -G131
701 ECT Overheat Test
702 Flexible Fuel Sensor -G133
703 CTP Recognition TPS/CTP Switch
705 Coolant Fan Switched on
709 Sunlight Photo Sensor 2-g134
710 Defroster Flap Motor -V107
711 Left Foot Well Flap Motor -V108
712 Right Foot Well Flap Motor -V109
713 Left Center Vent Motor -110
714 Right Center Vent Motor -V111
715 Rear Foot Well Vent Motor -V112
716 Recirculation Flap Motor -V113
717 EVAP Flap Motor -V114
718 Upper Left Vent Switch -F179
719 Upper Right Vent Switch -F180
720 Lower Left Vent Switch -F181
721 Left Right Vent Switch -F182
722 Left Center Vent Switch -F183
723 Right Center Vent Switch -F184
724 Left Center Foot Well Vent Switch -F185
725 Right Rear Foot Well Vent Switch -F186
726 Center Rear Foot Well Vent Switch -F187
727 Defroster Flap Motor - Position Sensor -G135
728 Left Center Vent Motor - Position Sensor -G136
729 Right Center Vent Motor - Position Sensor -G137
730 Center Vent Motor - Position Sensor -G138
731 Left Foot Well Flap Motor - Position Sensor -G139
732 Right Foot Well Flap Motor - Position Sensor -G140
733 Rear Foot Well Left Vent Motor - Position Sensor -G141
734 Center Vent Position Sensor -G142
735 Recirculation Flap Position Sensor -G143. * If this code is found on late model
VR6 (AAA) refer to code #01247.
736 EVAP Flap Motor. Position Sensor -G144
737 Left Heat Regulating Valve -N175
738 Rear Heat Regulating Valve -N176
739 Coolant Pump -V50
740 Cylinder 1 CKP Sensor -G145
741 Brake Pedal Position Status Monitoring
742 Battery Ventilation System
743 Battery Ventilation Sensor -G146
744 Battery Temperature Regulation
745 Insulation Status Monitoring
746 Battery Cell Failure
747 Front Battery Temperature Sensor -G52
748 Rear Battery Temperature Sensor -G53
749 Ventilation Flap
750 Fault Lamp Circuit
751 Battery Capacity Indicator
752 Fan and Battery Heating
753 Electrical Connector - Wheel Speed Sensor
754 ECT Warning Light
755 Engine Oil Pressure Warning Light -K3
756 Left Vent Temperature Sensor -G150
757 Left Vent Temperature Censor -G151
758 Secondary Air Injection System (Air)
759 Left Vent Temperature Regulator -G155
760 Right Vent Temperature Regulator (Actuator) -G156
761 Diagnostic Trouble Code Stored in Control Unit
762 Fuel Injector(s) -N181
763 Driver Side Gas Pressure Sensor -G147
764 Passenger Side Gas Pressure Sensor -G148
765 Slide Control Travel (Piston Displacement) Sensor -G149
766 Front Vent Temperature Sensor -G12
767 Rear Evaporator Temperature Sensor R-g153
768 Rear Heater Core Temperature Sensor -G154
769 Engine Coolant Temperature Sensor -G82
770 Engine Coolant Temperature Sensor -G83
771 Fuel Level Sensor -G
772 Oil Pressure Switch -F22
773 Oil Pressure Sensor -G10
774 Level Control System Sensor - Left Rear - G76
775 Level Control System Sensor - Right Rear - G77
776 Level Control System Sensor - Left Front - G78
777 Throttle Position Sensor -G79
778 Steering Angle Sensor -G85
779 Outside Air Temperature Sensor -G17
780 Vertical Motion Sensor -G90
781 Positioning Motor - Left Front -V76
782 Positioning Motor - Right Front - V77
783 Positioning Motor - Left Front - V78
784 Positioning Motor - Right Rear - V79
785 Temperature Sensor - Instrument Panel -G56
786 Temperature Sensor - in Headliner -G86
787 Fresh Air Intake Duct Temperature Sensor -G89
788 Foot Well/defrost Flap Two-wag Valve -N118
789 Backup Switch -F41
790 Recirculating/fresh Air Flap
791 Air Conditioner Evaporator Temperature Switch -G33
792 Air Conditioner Pressure Switch -F129
793 Brake Pedal Position Sensor -G100
794 Hydraulic Pump Sensor -G101
795 Rear Axle Vertical Acceleration Sensor -G102
796 Fan for Integer Temperature Sensor -V42
797 Sunlight Photo Sensor -G107
798 Segment Test
799 Engine Coolant Temperature Sensor -G110
800 Ambient Temperature Sensor Fresh Air Blower -G109
801 A/C Refrigerant High Pressure Switch -F11b
802 A/C Refrigerant Low Pressure Switch -F73
803 Coil Spring Travel Sensor - Right Front - G118
804 Coil Spring Trawl Sensor - Left Front -G115
805 Suspension Strut Valve - Left Front - N148
806 Suspension Strut Valve - Right Front - N149
807 Suspension Strut Valve - Left Front - N150
808 Suspension Shut Valve - Right Rear - N151
811 System Not Ready for Activation
824 Traction Control Indicator Light -K86
1016 Gas-filled Suspension Bleeder Valve -N106
1017 Gas-filled Suspension System Compressor -V65
1018 Coolant Fan -V7
1019 Relay
1020 Water Pump -V36
1021 Differential Lock Indicator Light -K81
1022 Interior Light - Combination Figure Activated
1023 Warning Buzzer -H3
1025 Malfunction Indicator Lamp Faulty
1027 Rear Warm Air Fan -V47
1028 Fan Relay -J323
1028 Rear Evaporator Fan -V20
1029 A/C Relay -J32
1039 ECT Sensor -G2
1040 ABS/Transmission Electrical Connection 2
1041 Traction Control System - Function Unreadable
1044 P1749 Transmission Control Module - Incorrectly Coded
1045 Tiptronic Switch -F189
1046 Broke Pod Wear Indicator Light -L32
1047 Brake and Parking Brake Warning Light -Kt
1048 Diesel Electronic Warning Light -K104
1049 Supply Voltage (Terminal 50)
1050 Glow Plug Status Monitoring
1051 Fuel MC Positioning Motor -V117
1052 Throttle Position Sensor -G157
1053 Injection Start-valve -N182
1054 Power Supply Relay (Terminal 30) -J317
1055 Injection Start-sensor -G158
1057 Function - Constant Charge - Voltage
1058 Function - Constant Charge - Current
1059 Rotor Position Sensor -G159
1060 Ignition Coil Lower Temperature Sensor -G160
1061 gnition Coil Upper Temperature Sensor -G161
1070 Starter Relay -J53
1071 Clutch Pedal Position Sensor -G162
1072 Clutch Position - Vacuum Valve -N183
1073 Clutch Pressure System
1074 Clutch Position - Vent Valve
1075 Vacuum Pump Relay -J320
1076 Hydraulic Pump Clutch Relay -J319
1077 Brake Booster Vacuum Switch -F190
1078 TR Gear Selector Switch -F191
1079 Power Steering Relay -J320
1080 Power Steering Pressure Switch -F192
1081 Priority Switch Valve -N185
1082 Low Fuel Level Warning Light -K105
1083 Low Windshield Fluid - Windshield Fluid Indicator Light or Sensor -K106
1084 32oF (0o) Freeze Temperature Warning Light -K107
1085 39oF (4o) Temperature Warning Light -K108
1086 Speedometer - Vehicle Speed Sensor -G22
1087 Basic Setting Not Performed
1088 Mixture Control Adjustment 2
1089 Tensioning Bow Raised Position Switch -F204
1090 Tensioning Bow Stowed Position Switch -F203
1091 Convertible Top Closed Position Switch -F202
1092 Convertible Top Open Position Switch -F171
1093 Compartment Cover Open Position Switch -F201
1094 Compartment Cover Left Switch 3-F195
1095 Compartment Cover Unlocked Left Switch 2-F197
1096 Comportment Cover Locked Left Switch 1-F199
1097 Convertible Top Front Lock Switch -F172
1098 Trunk Lid Closed Position Switch -F206
1099 Luggage Compartment Switch (Locked)
1100 Luggage Compartment Switch (Unlocked)
1101 Convertible Top Latch Open Position Switch -F205
1102 Compartment Cover Right Switch 3-F196
1103 Compartment Cover Unlocked Right Switch 2-F198
1104 Compartment Cover Locked Right Switch 1-F200
1105 Solenoid Valve 8-N186
1106 Power Window Opening Relay -J291
1107 Convertible Top Locked Indicator Light -K98
1108 Power Window Closing Relay -J292
1109 Convertible Top Hydraulic Pump Relay -J321
1110 Convertible Top Unlocking Solenoid -N187
1111 Luggage Compartment Lock Actuator Motor 1
1112 Actuator Motor 1 and 2 Power Supply
1113 Luggage Compartment Lock Actuator Motor 2
1114 Parking Brake Warning Light Switch -F9
1115 Just 3 Byte Space
1116 Convertible Top Unlocking Actuator Motor
1117 Generator Terminal DF Load Signal
1118 Engine Pre-heating Circuit
1119 Transmission Shift-Range Gear Position Signal
1120 Camshaft Adjustment 1
1121 Camshaft Adjustment 2
1122 Camshaft Position Sensor 2-G163
1123 Triggering Faulty
1124 Charge Time Status Monitoring
1125 Intake Manifold Change-over
1126 Engine Speed Signal
1127 Reserve Fuel Indicating Lamp
1128 Anti-theft System - Immobilizer Sensor -D2
1129 S-terminal -H15
1130 ABS Operation - Signal outside range of tolerance
1131 Blinking Light Activation
1132 Front Infrared Sensor -G166
1133 Rear Infrared Sensor -G167
1134 Alarm Horn -12
1135 Vehicle Interior-motion Sensor
1136 Engine Start Interrupt
1137 Central Locking Contact Switch
1138 Central Locking - Drivers Door Unlock
1139 Central Locking - Passenger Door Unlock
1140 Central Locking - Trunk Lid Unlock
1141 Trunk Lid Release Switch Motor
1142 Central Locking - Unlocking Motor
1143 Central Locking - Opening Motor
1144 Central Locking - Opening Motor
1145 Central Locking - Opening Motor
1146 Central Locking - Closing Motor
1147 Central Locking - Trunk Lid Release Motor -V120
1148 Save Fuse Door - Activation
1149 Save Fuse Door - Deactivating
1150 Analog Indicator
1151 Diesel Engine Safety Switch -F207
1152 TR Gear Monitoring Switch -F209
1153 E- (Economic) Switch - E163
1154 Clutch System Pressure Switch -F210
1155 Clutch, Mechanics
1156 TR Gear Recognition Switch -F208
1157 Alarm Horn Voltage Supply
1158 Turn Signal Voltage Supply
1159 Save Fuse Wiring
1160 Coolant Glow Plug Relay -J325
1165 Throttle Body Control Module -J338
1166 Engine Torque Signal
1167 Wide Open Throttle Stop - Throttle Stop Valve -N194
1168 Idle Rpm Increase Valve -N177
1169 Door Contact Switch - Driver Side -F2
1170 Fuel Injection Duration Sensor -G175
1172 Seat Heating Temperature Sensor - Driver Side -G59
1173 Longitudinal Adjustment Motor - Driver Side -V28
1174 Height Seat Adjustment - Driver Side -V38
1175 Heated Seat Adjustment - Driver Side - E94
1176 Key Faulty
1177 Engine Control Unit
1179 Incorrect Key Entry
1180 Engine / A/C - Electrical Connection
1181 Initializing - Only 2 Keys Pressed
1182 Height Adaptation
1183 Catalytic Convertor Warning Lamp -K72
1184 Outlet Temperature Sensor -G174
1185 Fresh Air Blower - Rear -V80
1186 Rear Air Distribution Servo Motor -V136
1187 Rear Temperature Flap Servo Motor -V137
1188 Control Module Solenoid - Electrical Connector
1190 Control Module Actuator Motor - Electrical Connector
1192 Torque Converter Clutch
1193 Low Heat Output -J359
1194 High Heat Output -J360
1196 Engine/Transmission Can Bus
1197 Engine/Transmission Can Bus - Wire-A
1198 Engine/Transmission Can Bus - Wire-B
1199 Engine/ABS Electrical Connection
1200 ABS Valves Voltage Supply - Fuse S54
1201 ABS Pump Voltage Supply - Fuse S53
1202 Diagnostic Wire
1208 Data Record Changes - VIN
1235 Secondary Air Injection - Solenoid Valve -N112
1236 Shift-Lock Solenoid -N110
1237 Fuel Cut-off Valve -N109
1238 Ignition Timing (Spark Angle) Control
1239 Throttle Position Actuator Vent Valve -N97
1240 Throttle Position Actuator Breather Valve -N117
1241 EVAP Canister Purge Solenoid Valve -N115
1242 Final Stage in Control Unit
1243 Intake Manifold Change-over Valve -Nix
1244 Heating Oxygen Sensor Control Module -J208
1245 Differential Pressure Regulator -N73
1246 Early Fuel Evaporation Relay -J81
1247 EVAP Canister Purge Regulator Valve -N80
1248 Wide Open Throttle Enrichment Two-way Valve -N54
1249 P0201 Cylinder 1 - Injector Fault -N30
1250 P0202 Cylinder 2 - Injector Fault -N31
1251 P0203 Cylinder 3 - Injector Fault -N32
1252 P0204 Cylinder 4 - Injector Fault -N33
1253 P0205 Cylinder 5 - Injector Fault -N83
1254 P0206 Cylinder 6 - Injector Fault -N84
1255 P0207 Cylinder 7 - Injector Fault -N85
1256 P0208 Cylinder 8 - Injector Fault -N86
1257 Idle Air Control Valve -N71
1258 Air Flap Positioner -V63
1259 Fuel Pump Relay Circuit -J17
1260 Deceleration Fuel Cut-off Valve -N55
1261 Oxygen Sensor Frequency Valve -N7
1262 Wastage Bypass Regulator Valve -N75
1263 Cold Start Injector -N17
1264 Secondary Air Injection Pump Relay -J299
1265 EGR Vacuum Regulator Solenoid Valve -N18
1266 Glow Plug Relay -J52
1267 Automatic Glow Time Control Unit -J179
1268 Quantity Adjuster -N146
1269 Injection Start Valve -N108
1270 A/C Compressor Clutch -N25
1271 Temperature Regulator Flap Motor -V68
1272 Central Air Flap Motor -V70
1273 Fresh Air Blower - V2
1274 Air Flow Flap Motor - V71
1275 Solenoid Relay
1276 ABS Hydraulic Pump - V64
1277 ABS Hydraulic Pump Relay -J185
1278 Electronic Differential Lock Cut-off Relay -J263
16486 P0102 Mass or Volume Air Flow Circuit - Low input
16487 P0103 Mass or Volume Air Flow Circuit - High Input. May be due to a low battery if
found with 17988 (P1580)
16496 P0112 IAT Sensor - Temp High - Circuit Low - G42
16497 P0113 IAT Sensor - Temp Low - Circuit High - G42
16500 P0116 Engine Coolant Temperature Circuit - Range/Performance Problem
16501 P0117 Engine Coolant Temperature Circuit - Low Input (High Temp)
16502 P0118 Engine Coolant Temperature Circuit - High Input (Low Temp)
16504 P0120 Throttle Position Sensor A - Circuit Malfunction
16505 P0121 Throttle Position Sensor A - Circuit - Performance Problem - Out of Range
16506 P0122 Throttle Position Sensor A Circuit - Low Voltage Input
16507 P0123 Throttle Position Sensor A Circuit - High Voltage Input
16509 P0125 Cooling System - Temp Too Low to Enter Closed Loop - G62
16514 P0130 O2 Sensor Circuit - Malfunction (Bank 1 Sensor 1)
16515 P0131 O2 Sensor Circuit - Voltage Low (Bank 1 Sensor 1)
16516 P0132 O2 Sensor Circuit - High Voltage (Bank 1 Sensor 1)
16517 P0133 O2 Sensor Circuit - Slow Response (Bank 1 Sensor 1)
16518 P0134 O2 Sensor Circuit - No Activity Detected (Bank 1 Sensor 1)
16519 P0135 O2 Sensor Heater Circuit - Malfunction (Bank 1 Sensor 1)
16520 P0136 O2 Sensor Circuit - Malfunction (Bank 1 Sensor 2)
16521 P0137 O2 Sensor Circuit - Low Voltage (Bank 1 Sensor 2)
16522 P0138 O2 Sensor Circuit - High Voltage (Bank 1 Sensor 2)
16524 P0140 O2 Sensor Circuit - Slow Response (Bank 1 Sensor 2)
16525 P0141 O2 Sensor Heater Circuit - Malfunction (Bank 1 Sensor 2)
16534 P0150 O2 Sensor Circuit - Malfunction (Bank 2 Sensor 1)
16536 P0152 O2 Sensor Circuit - High Voltage (Bank 2 Sensor 1)
16537 P0153 O2 Sensor Circuit - Slow Response (Bank 2 Sensor 1)
16538 P0154 O2 Sensor Circuit - No Activity Detected (Bank 2 Sensor 1)
16539 P0155 O2 Sensor Heater Circuit - Malfunction (Bank 2 Sensor 1)
16540 P0156 O2 Sensor Circuit - Malfunction (Bank 2 Sensor 2)
16542 P0158 O2 Sensor Circuit - High Voltage (Bank 2 Sensor 2)
16543 P0159 Sensor Circuit - Slow Response (Bank 2 Sensor 2)
16544 P0160 O2 Sensor Circuit - No Activity Detected (Bank 2 Sensor 2)
16545 P0161 O2 Sensor Heater Circuit - Malfunction (Bank 2 Sensor 2)
16554 P0170 Fuel Trim - Malfunction (Bank 1)
16555 P0171 Fuel Trim - System Lean (Bank 1)
16556 P0172 Fuel Trim - System Rich (Bank 1)
16557 P0173 Fuel Trim - Malfunction (Bank 2)
16558 P0174 Fuel Trim - System Lean (Bank 2)
16559 P0175 Fuel Trim - System Rich (Bank 2)
16684 P0300 Random Misfire Detected - Any Cylinder
16685 P0301 Cylinder #1 - Misfire Detected
16686 P0302 Cylinder #2 - Misfire Detected
16687 P0303 Cylinder #3 - Misfire Detected
16688 P0304 Cylinder #4 - Misfire Detected
16689 P0305 Cylinder #5 - Misfire Detected
16690 P0306 Cylinder #6 - Misfire Detected
16691 P0307 Cylinder #7 - Misfire Detected
16692 P0308 Cylinder #8 - Misfire Detected
16706 P0322 Ignition/Distributor Engine Speed Input Circuit - No Signal
16711 P0327 Knock Sensor #1 Circuit - Low Input (Bank 1 or Single Sensor)
16716 P0332 Knock Sensor #2 Circuit - Low Input (Bank 2)
16721 P0337 Crankshaft Position Sensor Circuit - Low Input
16725 P0341 Camshaft Position Sensor Circuit - Out of Range/Performance
16784 P0400 Exhaust Gas Recirculation (EGR) - Flow Malfunction
16785 P0401 Exhaust Gas Recirculation (EGR) - Flow Insufficient
16786 P0402 Exhaust Gas Recirculation (EGR) - Flow Excessive
16795 P0411 Secondary Air Injection System (B2) - Incorrect Flow
16806 P0422 Main Catalyst Efficiency - Below Threshold (Bank 1)
16816 P0432 Main Catalyst Efficiency - Below Threshold (Bank 2)
16824 P0440 Evaporative Emission Control System (EVAP) - Purge Malfunction
16825 P0441 Evaporative Emission Control System - Incorrect Purge Flow
16826 P0442 Evaporative Emission Control System - Leak Detected (small leak)
16836 P0452 Evaporative Emission Control System - Pressure Sensor - Low Input
16837 P0453 Evaporative Emission Control System - Pressure Sensor - High Input
16839 P0455 Evaporative Emission Control System - Leak Detected (gross leak)
16845 P0461 Fuel Level Sensor Circuit - Range/Performance
16885 P0501 Vehicle Speed Sensor - Range/Performance
16890 P0506 Idle Control Module - RPM Lower Than Expected
16891 P0507 Idle Control Module - RPM Higher Than Expected
16894 P0510 Throttle Position Sensor - Closed Switch
16989 P0605 Internal Control Module Read Only Memory (EPROM) Error
17090 P0706 Transmission Range Sensor Circuit - Range/Performance
17091 P0707 Transmission Range Sensor Circuit - Low Input
17509 P1101 O2 Sensor Circuit (B1-S1) Voltage Too Low/Air Leak
17510 P1102 O2 Sensor Circuit Heating Circuit (B1-S1) - Short to B+
17511 P1103 O2 Sensor Circuit Heating Circuit (B1-S1) - Output Too Low
17512 P1104 O2 Sensor Circuit (B1-S2) Voltage Too Low - Air Leak
17513 P1105 O2 Sensor Circuit Heating Circuit (B1-S2) -Short to B+
17514 P1106 O2 Sensor Circuit (B2-S1) Voltage Too Low - Air Leak
17515 P1107 O2 Sensor Circuit Heating Circuit (B2-S1) - Short to B+
17516 P1108 O2 Sensor Circuit Heating Circuit (B2-S1) - Output too Low
17517 P1109 O2 Sensor Circuit (B2-S2) Voltage Too Low - Air Leak
17518 P1110 O2 Sensor Circuit Heating Circuit (B2-S2) - Short to B+
17535 P1127 Long Term Fuel Trim - System too Rich (Bank 1)
17536 P1128 Long Term Fuel Trim - System too Lean (Bank 1)
17609 P1201 Cylinder #1 Fuel Injector Circuit - Electrical Malfunction
17610 P1202 Cylinder #2 Fuel Injector Circuit - Electrical Malfunction
17611 P1203 Cylinder #3 Fuel Injector Circuit - Electrical Malfunction
17612 P1204 Cylinder #4 Fuel Injector Circuit - Electrical Malfunction
17613 P1205 Cylinder #5 Fuel Injector Circuit - Electrical Malfunction
17614 P1206 Cylinder #6 Fuel Injector Circuit - Electrical Malfunction
17615 P1207 Cylinder #7 Fuel Injector Circuit - Electrical Malfunction
17616 P1208 Cylinder #8 Fuel Injector Circuit - Electrical Malfunction
17621 P1213 Cylinder #1 Fuel Injector Circuit - Short to B+
17622 P1214 Cylinder #2 Fuel Injector Circuit - Short to B+
17623 P1215 Cylinder #3 Fuel Injector Circuit - Short to B+
17624 P1216 Cylinder #4 Fuel Injector Circuit - Short to B+
17625 P1217 Cylinder #5 Fuel Injector Circuit - Short to B+
17626 P1218 Cylinder #6 Fuel Injector Circuit - Shod to B+
17627 P1219 Cylinder #7 Fuel Injector Circuit - Shod to B+
17628 P1220 Cylinder #8 Fuel Injector Circuit - Shod to B+
17633 P1225 Cylinder #1 Fuel Injector Circuit - Short to Ground
17634 P1226 Cylinder #2 Fuel Injector Circuit - Short to Ground
17635 P1227 Cylinder #3 Fuel Injector Circuit - Short to Ground
17636 P1228 Cylinder #4 Fuel Injector Circuit - Short to Ground
17637 P1229 Cylinder #5 Fuel Injector Circuit - Short to Ground
17638 P1230 Cylinder #6 Fuel Injector Circuit - Short to Ground
17639 P1231 Cylinder #7 Fuel Injector Circuit - Short to Ground
17640 P1232 Cylinder #8 Fuel Injector Circuit - Short to Ground
17645 P1237 Cylinder #1 Fuel Injector Circuit - Open Circuit
17646 P1238 Cylinder #2 Fuel Injector Circuit - Open Circuit
17647 P1239 Cylinder #3 Fuel Injector Circuit - Open Circuit
17648 P1240 Cylinder #4 Fuel Injector Circuit - Open Circuit
17649 P1241 Cylinder #5 Fuel Injector Circuit - Open Circuit
17650 P1242 Cylinder #6 Fuel Injector Circuit - Open Circuit
17651 P1243 Cylinder #7 Fuel Injector Circuit - Open Circuit
17652 P1244 Cylinder #8 Fuel Injector Circuit - Open Circuit
17656 P1250 Fuel Level Too Low
17733 P1325 Cylinder #1 Knock Control Limit Attained
17734 P1326 Cylinder #2 Knock Control Limit Attained
17735 P1327 Cylinder #3 Knock Control Limit Attained
17736 P1328 Cylinder #4 Knock Control Limit Attained
17737 P1329 Cylinder #5 Knock Control Limit Attained
17738 P1330 Cylinder #6 Knock Control Limit Attained
17739 P1331 Cylinder #7 Knock Control Limit Attained
17740 P1332 Cylinder #8 Knock Control Limit Attained
17747 P1339 Crankshaft Position/Engine Speed Sensors Cross connected
17748 P1340 Camshaft/Crankshaft Position Sensors (B2) - Out of Sequence
17749 P1341 Ignition Coil Power Output Stage #1 - Short to Ground
17751 P1343 Ignition Coil Power Output Stage #2 - Short to Ground
17753 P1345 Ignition Coil Power Output Stage #3 - Short to Ground
17799 P1391 Camshaft Position Sensor (B2) - Short to Ground
17800 P1392 Camshaft Position Sensor Open (B2) - Short to B+
17801 P1393 Ignition Coil Power Output Stage #1 - Electrical Malfunction
17802 P1394 Ignition Coil Power Output Stage #2 - Electrical Malfunction
17803 P1395 Ignition Coil Power Output Stage #3 - Electrical Malfunction
17804 P1396 Engine Speed Sensor - Missing Tooth
17808 P1400 EGR Valve Circuit - Electrical Malfunction
17809 P1401 EGR Valve Circuit - Power Stage Short to Ground
17810 P1402 EGR Valve Circuit - Short to B+
17815 P1407 EGR Temperature Sensor - Signal too Low
17816 P1408 EGR Temperature Sensor - Signal too High
17817 P1409 Tank Ventilation Valve - Electrical Malfunction
17818 P1410 Tank Ventilation Valve - Short to B+
17819 P1411 Secondary Air Injection System (B2) - Restricted Flow
17822 P1414 Secondary Air Injection System (B2) - Leak Detected
17826 P1418 Fuel Level Sensor - Signal too High
17828 P1420 Secondary Air Injection System Control Module - Electrical Malfunction
17829 P1421 Secondary Air Injection System Control Valve Circuit - Short to Ground
17830 P1422 Secondary Air Injection System Control Valve Circuit - Short to B+
17831 P1423 Secondary Air Injection System (B1) - Flow too Low
17832 P1424 Secondary Air Injection System (B1) - Leak Detected
17833 P1425 Tank Ventilation Valve - Short to Ground
17834 P1426 Tank Ventilation Valve - Open Circuit
17842 P1434 Secondary Air Injection System Pump Relay Circuit - Short to B+
17844 P1436 Secondary Air Injection System Pump Relay Circuit - Electrical Malfunction
17848 P1440 EGR Valve Circuit - Power Stage Open
17858 P1450 Secondary Air Injection System Pump Relay Circuit - Short to B+
17859 P1451 Secondary Air Injection System Pump Relay Circuit - Short to Ground
17860 P1452 Secondary Air Injection System Pump Relay Circuit - Open Circuit
17878 P1470 EVAP Emission Control System L.D.P Circuit - Malfunction
17879 P1471 EVAP Emission Control System L.D.P. Circuit - Short to B+
17883 P1475 EVAP Emission Control System L.D.P. - Malfunction Signal Circuit open
17884 P1476 EVAP Emission Control System L.D.P. - Malfunction/Insufficient Vacuum
17908 P1500 Fuel Pump Relay Circuit - Electrical Malfunction
17910 P1502 Fuel Pump Relay Circuit - Short to B+
17912 P1504 Intake Air System Bypass Air Determined
17913 P1505 CTP Switch not Closing - Open Circuit
17914 P1506 CTP Switch not Opening - Short to Ground
17917 P1509 IAC Circuit - Electrical Malfunction
17918 P1510 IAC Circuit - Short to B+
17919 P1511 Intake Manifold Changeover Valve Circuit - Electrical Malfunction
17920 P1512 Intake Manifold Changeover Valve Circuit - Short to B+
17951 P1543 Throttle Actuation Potentiometer - Signal too Low
17952 P1544 Throttle Actuation Potentiometer - Signal too High
P1545
P1559
17988 P1580 Throttle Actuator (B1) Fault - May be caused by low battery if found with 16487
(P0103)
17990 P1582 Idle Adaption at Limit
18008 P1600 Power Supply (B+) Terminal 15 - Low Voltage
18010 P1602 Power Supply (B+) Terminal 30 - Low Voltage
18014 P1606 Rough Road Spec. Engine Torque ABS-SG - Electrical Malfunction
18019 P1611 MIL Call-up Circuit/Transmission Control Module - Short to Ground
18020 P1612 ECM - Incorrectly Coded
18021 P1613 MIL Call-up - Circuit Open or Short to B+
65535 P0603 Control Unit Failure or Internal Control Module Keep Alive Memory (KAM) Error
or Power Failure to Control Unit or Bad Ground Contacts or No Faults Recorded
(If MIL Not Illuminated)
65535 No Faults Recorded (If MIL Not Illuminated)
65535 Control Unit Faulty (In Some Systems)
P0217 Temp Light - Engine Hot
P0218 Temp Light - Transaxle Hot
P0326 Knock Sensor - Constant Knock
P0351 Ignition - Faulty
P0352 Ignition - Faulty
P0420 Converter - Low Efficiency
P0443 EVAP Purge - Circuit Fault
P0500 VSS Sensor - No Signal
P0560 Battery Voltage - Out of Range
P0561 Battery Voltage - Unstable
P0562 Battery Voltage - Low
P0563 Battery Voltage - High
P0565 Cruise Control - Circuit Fault
P0571 Brake Switch - Circuit Fault
P0572 Brake Switch - Low Voltage
P0573 Brake Switch - High Voltage
P0600 PCM - No Serial Data
P0601 EPROM - Fault
P0602 PCM Program - Fault
P0604 PCM RAM Memory - Fault
P0606 PCM Processor - Fault
P1782 Engine/Transmission Data Electrical Connection Ignition Intervention. Also check
Newb question: this codes are the same for 1995 16v 2l ?
edit: I think I have found answer already... it says ALL Corrados are OBD 1, unless been converted to ODB 2 :(
