cardboard 0 Posted March 17, 2010 the boot latch is not engaging when the boot is closed? i have tried spraying WD40 into it etc but to no avail? is this common? do i need a replacement or is there and easy fix? thanks Quote Share this post Link to post Share on other sites
sprayteck 0 Posted April 2, 2010 hi, try using a screw driver as a stricker pin to activate the lock mech when the boot is open. if it clicks locked and you can then release it with the button, repeat it a few times to be 100% sure the mech is working. if it doesnt do this then the mech is dead im affraid. if it is working then the pin on the rear panel will have slipped down or bent, preventing the mech from engaging the pin. so you would have to adjust the pin up so that the mech can engage the pin again. capiche? haha good luck pal. si Quote Share this post Link to post Share on other sites
