A5 VRX
CV Boot/ Driveshaft
Just had the VR up on the ramps and the drivers side inner driveshaft boot is knackered, do i need a new driveshaft (got a little play in it) or just the boot? Either way where can i get one? Exchange basis only? Garage quoted me about 130 +VAT,
Cheers
Adam
the boot shouldnt be very expensive, to do it, the driveshafts need s taking out, drop the lower ball joint off the hub, the driveshaft nut off, and remove shaft. then the boot can be replaced, more labour than any thing.
Looking to buy an inner drivers side CV boot then, GSF or dealers? Any part numbers?
Thanks peeps
AJ
