volksworld13 0 Posted March 28, 2010 hi everyone need a little help with a wiring diagram, just bought a 95 vr6, will not start on the ignition switch, it has a dealer fit immobilser , with a fob you insert into the drivers side lower shelf to unlock it, and then put key in and start. i have removed this old system , but the loom looks so well fitted and splicing staright into the rear of the fuse box, all rmoved now, im left with the main satrter ignition lead black/red spade connector near the fuse box, but no where for it to go, as this connector was plugged into the old immobiliser system, has any want removed one of these suckers, as the wiring is well in there and i dont have a a wiring diagram of the starting circuit, ive read theres no starter relay? i have no ignition lights either, i have swaped the ignition switch with a known good one, and still the same, if anyone has a wirind diagram and connector pin out for the ignition switch to the starter solonid, id be much appreciated. the main red/bk wire is the solonoid wire ,but im unable to locate where this sits in the back of the fuse box? black spade terminal from the switch to the fusebox, regards alex Quote Share this post Link to post Share on other sites
volksworld13 0 Posted March 28, 2010 all sorted bk/rd wire h1 pin 1, still no crank traced fault to ignition switch, !all sorted big thanks to yandards for wiring info.! Quote Share this post Link to post Share on other sites
ANDREW 30 0 Posted March 28, 2010 Just been to dig out my bently manual and got back to my pc to see your sorted out! Quote Share this post Link to post Share on other sites
volksworld13 0 Posted March 28, 2010 thanks anyway buddy, fancy selling me your bentley manual? :norty: Quote Share this post Link to post Share on other sites
